Displays detailed system-related information.
| mgmt | Specifies the management port. |
| port_list | Specifies one or more ports of slots and ports. |
| tag | Specifies an 802.1Q or 802.1ad tag value. |
| detail | Specifies detailed port information. |
N/A.
This command displays information, including the following:
If you do not specify a port number, range of ports, or tag value, detailed system-related information is displayed for all ports. The data is displayed in a table format.
The tag value may be associated with either a VMAN or a VLAN.
This status information may be useful for your technical support representative if you have a network problem.
The detail parameter is used to provide more specific port information. The data is called out with written explanations versus displayed in a table format.
The detail parameter displays slightly different information depending on the platform and configuration you are working with.The link filter counter displayed with the detail parameter is calculated at the middle layer on receiving an event. The link filter up indicates the number of link transitions from down to up at the middle layer filter.
The following command displays port system-related information on a switch:
# show ports 25 information
                                        ELSM/
Port      Flags               Link       OAM/   Link Num  Num   Num Jumbo QOS     Load
                              State     MACsec   UPS STP VLAN Proto  Size profile Master
25        Em---------fMB-S-x- active    - / -/up   3   0    1     1  9216 none
> indicates Port Display Name truncated past 8 characters
Flags : a - Load Sharing Algorithm address-based,
        b - Rx and Tx Flow Control Enabled, B - Broadcast Flooding Enabled,
        D - Port Disabled, e - Extreme Discovery Protocol Enabled,
        E - Port Enabled, f - Unicast Flooding Enabled,
        F - Priority Flow Control Enabled, G - MLAG Enabled, i - Isolation,
        j - Jumbo Frame Enabled, l - Load Sharing Enabled,
        L - Extreme Link Status Monitoring Enabled,
        m - MACLearning Enabled, M - Multicast Flooding Enabled,
        n - Ingress TOS Enabled, o - Dot1p Replacement Enabled,
        O - Ethernet OAM Enabled, p - Load Sharing Algorithm port-based,
        P - Software redundant port(Primary),
        R - Software redundant port(Redundant),
        s - diffserv Replacement Enabled, S - MACsec Enabled,
        v - Vman Enabled, w - MACLearning Disabled with Forwarding,
        x - Rx Flow Control Enabled
            # show ports 25 information detail
Port:   25
        Virtual-router: VR-Default
        Type:           UTP
        Random Early drop:      Unsupported
        Admin state:    Enabled with  auto-speed sensing  auto-duplex
        MACsec Link State:      Up
        Link State:     Active, 1Gbps, full-duplex
        Link Ups:       3        Last: Fri Dec 08 16:26:55 2017
        Link Downs:     1        Last: Fri Dec 08 16:18:12 2017
        VLAN cfg:
                 Name: MACsec_1000, Internal Tag = 1000, MAC-limit = No-limit, Virtual router:   VR-Default
        STP cfg:
        Protocol:
                 Name: MACsec_1000  Protocol: ANY      Match all protocols.
        Trunking:       Load sharing is not enabled.
        EDP:            Disabled
        EEE:            Disabled
        ELSM:           Disabled
        Ethernet OAM:           Disabled
        MACsec:         Enabled
The following example displays the current status of non-Extreme optical devices:
 # show ports 3 information detail
Port:   3
        Type:            Q+SR4       (Licensed)       or
                                     (Unlicensed)     or
                                     (Restricted)
        Link State:      Ready
        Link Ups:        0         Last:  --
        Link Downs:      0         Last: --
        VLAN cfg:
                Name: Default, Internal Tag = 1, MAC-limit = No-limit, Virtual router:   VR-Default
        STP cfg:
                s0(disable), Tag=(none),  Mode=802.1D, State=FORWARDING
        Protocol:
                Name: Default       Protocol: ANY       Match all protocols.
        EDP:             Enabled
        ELSM:            Disabled
        Learning:         Enabled
        Unicast Flooding:        Enabled
        Multicast Flooding:      Enabled
        Broadcast Flooding:      Enabled
        Jumbo:           Disabled
        Flow Control:    Rx-Pause: Enabled        Tx-Pause:     Disabled
        Priority Flow Control: Disabled
        Reflective Relay:        Disabled
        Link up/down SNMP trap filter setting:   Enabled
        Egress Port Rate:        No-limit  (Restricted, 10 Gbps maximum)
        Broadcast Rate:          No-limit
        Multicast Rate:          No-limit
        Unknown Dest Mac Rate:   No-limit
        QoS Profile:     None configured
        Ingress Rate Shaping :           Unsupported
        Ingress IPTOS Examination:       Disabled
            The following output displays show port info detail that has port-specific tag.
Port:   3
            Virtual-router: None
            Type:           BASET
            Admin state:    Enabled with  10G full-duplex
            Link Ups:       0        Last: Wed Jun 05 00:29:24 2013
            VLAN cfg:       Name: test, 802.1Q Tag = 200, MAC-limit = No-limit,
            Virtual router:   VR-Test
                Port-specific VLAN ID: 10, 11, 200
            Name: test2, 802.1Q Tag = 300, MAC-limit = No-limit,
            STP cfg:
            Protocol:
            EDP:            Disabled
            ELSM:           Disabled
            Learning:       Enabled
            Jumbo:  Enabled, MTU= 9216
            Ingress 802.1p Examination:     Enabled
            Ingress 802.1p Inner Exam:      Disabled
            Egress IPTOS Replacement:       Disabled
            Egress 802.1p Replacement:      Disabled
            NetLogin:                       Disabled
            NetLogin port mode:             Port based VLANs
            Smart redundancy:               Enabled
            Software redundant port:        Disabled
            IPFIX:   Disabled               Metering:  Ingress, All Packets, All Traffic
            IPv4 Flow Key Mask:     SIP:  255.255.255.255            DIP: 255.255.255.255
            IPv6 Flow Key Mask:     SIP:  ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
            DIP:   ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
            Far-End-Fault-Indication:       Disabled
            Shared packet buffer:           default
            VMAN CEP egress filtering:      Disabled
            Isolation:                      Off
            PTP Configured:                 Disabled
            Time-Stamping Mode:             None
            Configured Port Partition:      4x10G
            Current Port Partition:         4x10G
            Available Port Partitions:      1x40G, 4x10G, 1x100G, 2x50G, 4x25G
            Synchronous Ethernet:           Unsupported
            Dynamic VLAN Uplink:            Disabled
            VM Tracking Dynamic VLANs:      Disabled
            Forward-Error-Correction:       Disabled
            The following example shows LRM/MACsec Adapter port state information (in bold):
Port: 3
      Type:       SF+_CX1m (Unsupported) (LRM/MACsec Adapter)
      LRM/MACsec Adapter port state:      Operational
      Link State: Active, 10Gbps, full-duplex
      Link Ups:       1        Last: Fri Aug 16 12:07:01 2019
      VLAN cfg:
      STP cfg:
            s0(enable), Tag=(none), Mode=802.1D, State=FORWARDING
      Protocol:
      EDP:        Enabled
      ELSM:       Disabled
      MACsec:           Disabled
      Learning:   Enabled
      Link-Flap Detection:    Disabled
      Jumbo:            Disabled
      Ingress 802.1p Priority:        0
      NetLogin:               Disabled
      Isolation:              Off
        The following command displays the indication that a 25G lane-based optic has been inserted into a port partitioned for 10G lanes (lines 4-5):
(pacman debug) switch-model-EXOS.6 # show port 25 information detail
Port:   25
        Type:           Q28+SWDM4 (Mismatches Partition)
        Admin state:    Enabled with  40G full-duplex
        Link State:     Ready
        VLAN cfg:
        STP cfg:
                s0(enable), Tag=(none), Mode=802.1D, State=DISABLED
        Protocol:
        EDP:            Enabled
        ELSM:           Disabled
        MACsec:         Disabled
        Learning:       Enabled
        Jumbo:          Disabled
        QOS Profile Settings:     QP1  MinBw =     0%  MaxBw =   100%  MaxBuf =   100%  Weight =    1
                                  QP8  MinBw =     0%  MaxBw =   100%  MaxBuf =   100%  Weight =    1
        NetLogin:                       Disabled
        Isolation:                      Off
        Port Partition:                 1x40G
        Available Port Partitions:      1x40G, 4x10G, 2x50G, 4x25G
        The following command displays the indication that a 100G optic has been inserted into an unlicensed port (lines 4-5):
(pacman debug) X870-32c.2 # show port 1 info detail
Port:   1
        Type:           Q28+SWDM4 (Mismatches Partition) (Unlicensed)
        Link State:     Ready
        VLAN cfg:
        STP cfg:
        Protocol:
        EDP:            Enabled
        ELSM:           Disabled
        MACsec:         Disabled
        Learning:       Enabled
        The following command displays port information with ingress filtering for MAC-based VLANs enabled:
# show ports 1:2 information detail
Port:   1:2
        Type:           UTP
        Link State:     Ready
        VLAN cfg:
                 Name: SYS_VLAN_0300, Internal Tag = 300(MAC-Based with ingress filtering on), MAC-limit = No-limit, Virtual router:   VR-Default
                 Name: SYS_VLAN_0301, Internal Tag = 301(MAC-Based with ingress filtering on), MAC-limit = No-limit, Virtual router:   VR-Default
                 Name: SYS_VLAN_0500, 802.1Q Tag = 500, MAC-limit = No-limit, Virtual router:   VR-Default
                       Port-specific VLAN ID:  500
                 Name: SYS_VLAN_0501, 802.1Q Tag = 501, MAC-limit = No-limit, Virtual router:   VR-Default
                       Port-specific VLAN ID:  501
        STP cfg:
        Protocol:
                 Name: SYS_VLAN_0301 Protocol: ANY      Match all protocols.
                 Name: SYS_VLAN_0300 Protocol: ANY      Match all protocols.
        EDP:            Enabled
        EEE:            Disabled
        ELSM:           Disabled
        MACsec:         Disabled
        Learning:       Enabled
        Jumbo:          Disabled
        NetLogin:                       Disabled
        NetLogin port mode:             MAC based VLANs with ingress filtering on
        auto-polarity:                  Enabled
        Isolation:                      Off
        The following command displays port information for ports 23 and 24 with MDI and MDIX mode configured and auto-polarity disabled:
# show port 23 information detail | in polarity
        auto-polarity:                  Disabled (MDI)
            # show port 24 information detail | in polarity
        auto-polarity:                  Disabled (MDIX)
Information on ingress rate shaping was added in ExtremeXOS 11.0.
Network Login, Smart Redundancy, and rate limiting were added in ExtremeXOS 11.1.
Information on unicast, multicast, and broadcast flooding; the Port not present parameter; and autopolarity status were added in ExtremeXOS 11.2.
The netlogin parameters were added in ExtremeXOS 11.3.
The output command was modified in ExtremeXOS 12.1 so that when learning is disabled with the disabled learning port command, a new w flag appears in the output.
Link Ups and Link Downs information was added to the output and the tag value was added to the command syntax in ExtremeXOS 12.4.4.
Industrial Temperature detail added to Type field in ExtremeXOS 15.1.2.
The Industrial Temperature detail is only displayed only when detail is used. Without it, the output is compressed and the optic type is not displayed.The show output was enhanced to display the SNMP ifMib ifAlias accessible string size information.
The show output was updated to include the current status of non-Extreme optical devices in ExtremeXOS 15.4.
Link-flap detection information was added in ExtremeXOS 22_1.
Available Port Partitions was added to show port speed licensing information for ExtremeSwitching X870-96x-8c switches in ExtremeXOS 22.2.
IEEE Forward Error Correction (FEC) Clause 74 or 91 modes status was added in ExtremeXOS 22.3.
MACsec flag (S) and LRM/MACsec adapter in the detail Type field was added in ExtremeXOS 30.1.
LRM/MACsec Adapter port state information was added in ExtremeXOS 30.4.
Mismatched port compatility indication was added in ExtremeXOS 31.3.
Ingress filtering for MAC-based VLANs was added in ExtremeXOS 31.5.
mdi-mode information was added in version 32.6.
